Displays the MPLS interface information. Information is displayed in tabular format for all VLANs that have been added to MPLS.
| vlan | Specifies to display information for one VLAN. |
| vlan_name | Specifies the name of the VLAN. |
| detail | Specifies to display additional status information about the interface. |
N/A.
Specifying the optional detail keyword displays the information in verbose form and also includes the operational state for RSVP-TE and LDP. Specifying a VLAN limits the output to that of the individual VLAN.
The following command display MPLS interface information:
Switch # show mpls interface Local RSVP-TE LDP VLAN Name IP Address MTU UpTm #Nbr UpTm #Adj Flags ---------------- --------------- ---- ---- ---- ---- ---- ------- loopb 11.100.100.218 1500 3h 0 3h 0 MRL-I-U toratora 192.84.86.1 1500 3h 0 3h 1 MRL-IBU tordoze 192.84.93.1 1500 3h 0 3h 1 MRL-IbU torfour 192.84.83.1 1500 -- 0 -- 0 MRL-I-- torinasp 192.84.85.1 1500 -- 0 -- 0 MRL-I-- Flags: (M) MPLS Enabled, (R) RSVP-TE Enabled, (L) LDP Enabled, (P) PHP Enabled, (I) IP Forwarding Enabled, (B) BFD Enabled, (b) BFD Disabled(Sessions Exist) (U) MPLS Operational
The following command displays detailed MPLS information for VLAN 1:
# show mpls interface vlan1 detail VLAN Name : vlan1 Local IP Address : 192.84.86.1 IP Forwarding : Enabled MPLS I/F MTU : 1500 PHP Status : Disabled BFD Status : Enabled MPLS Admin Status : Enabled MPLS Oper Status : Disabled RSVP-TE Admin Status : Enabled Oper Status : Disabled UpTime : 0d:0h:0m:0s # Neighbors : 0 LDP Admin Status : Enabled Oper Status : Disabled UpTime : 0d:0h:0m:0s # Link Adjacencies : 0
This command was first available in ExtremeXOS 11.6.
The BFD flags and status were first available in ExtremeXOS 12.4.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
